Engine swaps?
Hey guys I posted a while back asking about standard k11 engine parts but now I'm wondering if there are any 1.6 engines that bolt straight into these beasts?
Preferably ones that I won't have to change the gearbox either but that's hard to come by :/ cheers everyone
Lol but yeah, GA16 bolts to the CG gb ok (the 1.3 one at any rate). But if you're using stock gb mounts/shafts etc and don't wanna shift the gb over, you'll need electric water pump, and you'll need to lose the PAS and AC pumps and use only one belt (for the alternator), grind off the pulley runs on the crank pulley so you are left with the single belt section (for the alternator belt) and make a custom engine mount.
