have some problems with my k12 2005, engine is stalling while driving, and after it's stalling it's hard to start again. Have changed the crank sensor and cam shaft sensor but still got the problem, the car can work fine for days and the it can come 4-5 times per day. could it be some o2 sensor or some ignition problems? or is it the coil? some times when i start it my micra have very low RPM on idling and even the lights will not come on intil i give it pedal to the metall
the code reader says it's the crank sensor is faulty, but the car can stop and no error code can pop up.
Please help. have been in to the garage 3 times and still no fix for it
