Hi! I just installed new throttle body to my nissan micra k11. I then adjust the idle control, it idles fine but with the aicondition on it stalls and shuts the engine off..please help me..
Ok, I will check the relay, thanks! Do I still need to bring the car to an electrician for him to reset or clear the error code referring to mass airflow sensor?
My car is nissan micra k11, cg13 1995 model.. what about the waxtat? Does it helps to prevent the car from shutting off if I turn the aircon on by adjusting to higher settings?-
