Baz
Lads I use my st on track alot, like its been on 3 trackdays this year alone.
It always let out a bit of blue smoke on gear changes at high revs never thought much of it as the compression was good enough on it ,still is ok aswell.
Basically there's been no expense spared when it comes to servicing this car, but the last few months I've been driving it on the road and some mornings I start it cold and small bit of blue smoke comes out of it for a few seconds after starting but she's grand once she's fully warmed up.
I have changed brand of oil but its a top brand aswell ,I was using redline 15w/50 never found it that smokey ,now using Mobil 1 15w/50
Now the engine has alot more to go before it needs to be ripped apart for a rebuild, but is it the rings starting to go or wear on the valve stem oil seals?
Also there's the issue of not being able to get rings for it? Could I get a set made?
Please discuss
Baz
Please discuss
Baz
