hoopdub
Club Member (Trial)
is it possible to remove the engine from a k11 without taking the box out at the same time? not that im looking to save time, i just cant be arsed with draining the box and getting oil on my drive then having to buy new gear oil bla bla im only swapping the engine from a 1L to a 1.3. if its more hasstle than its worth then i wont bother, will just bite the cash bullet.
also any tips from you guys who have done the engine out a few times (frank ) haynes says to drop it on the floor, but have no means of lifting the car high enough to do that.
also my plan is to take off the inlet manifold in situ and zip tieing it to the bulkhead out the way so i dont have to remove any pipes and wires and stuff, the 1.3 has the exhaust mani left on it and the small cat has had its innerds punched out, will swap the flywheel and clutch over then pop the other block in.
tip and hints welcome
