Hi everyone,
has anyone used engine oil in their gearbox with the intention of reducing drag in the gearbox
from the heavy gearbox oil used as normal, and if so was there any problems, damage etc,
thanks guy's.
Never seen the need to personally
70w90 is bob on for gearboxes. Not as tight a tolerance as engine bearings so I can't see it lubricating properly and falling through the gaps
Moly-slip I find a good additive as it sticks to the gears and protects em. They're is a mild noticeable difference when its pushed hard
Hey Skymera,
you must have been on a "tight budget" using used engine oil!, did you notice any difference in performance "honestly" and would you advise using it or not using it????...
it stops the gears being notchy on a winter startup mate, and for cheapness too, and millions of austin rovers used the g/box under the engine as a sump (mini,s etc) and yes mine is still full of used engine oil
Thank's Frank, and all of you that responded!,
I know motorbikes use the same engine oil in the gearbox and they have no issues
as well as ATV'S etc, thanks again guy's!!!..
