CMF_ra100slav
» CMF MemberPlese does enybody know what should be problem??? When I want to start my micra (model 97,) engine management light start flashing - I got explanation that this is because of ECU went to lock mode. Really weird is that after several attemps to start engine(remove key/pos1/pos2/ignition) - management light stay ON=everything is OK-, but not everytime. In this case helps disconnect battery overnight&in the morning is againg everything OK. (I have red knob immobilizer key).
Please any ideas what it shoudl be???
Thanx.
Thanx.
