wehey
i installed the rebuilt 1.3 today and it seems to be running well apart from an oil leak from the crankshaft pulley seal.
Before the questions, the engine internals are stock apart from a 1mm head skim to raise the compression.
So I got it all warmed up and went for a spin then checked the timing with a strobe. It was at 0 degrees so I went to alter it and the max it would advance to was 10 degrees.
So I set it there and went out for a drive. I noticed it was pinking, so went home and set it to 5 degree which seemed to sort it.
Next I checked the compression and was very suprised
All cylinders the same.
So the questions.
I've never used a strobe before. Do you set the timing with the engine on tickover?
Why couldn't I adjust to 15 degrees? Was this because I have used the strobe incorrectly
The compression seems very high to me. Is this what I would expect from a 1 mm head skim?
So the questions.
