Hi All
I have serviced a Micra c+c 2007 i.e spark plugs air filter, oil, and oil filter. I have now put everything back together, but now on idle it is fluctuating between 1500 and 2000 revs. I have fitted new TB gasket and Inlet manifold seals. I have checked for air leaks Visually as well as with propane and carb cleaner but I cant find any leaks. I have no Engine check lights on.
Could someone please advice as to what the manifold to head torque setting is .
Any other suggestions about the above fault welcome.
