chriswills Nov 6, 2014 #1 Been garage to diagnose engine light. Turns out,after flat battery,it recalls all previous faults and so brings eml on. So if after low or flat battery you have the same dont immediately panic,as its prob just that.
M Master tech Nov 6, 2014 #2 It throws loads of can bus faults u1000. Usualy bcm faults also. All system erase and idle air volume learn.
OP OP chriswills Nov 9, 2014 #3 Is it worth buying a fault code canceller for occadions when battery dies to save this problem in the future? Seen some basic ones for 20-30 on ebay
M Master tech Nov 10, 2014 #4 They will only go into the ecu and not all systems. A code reader is always handy to have though.
