Electronic Carb??
P
pw2002
on my K10 the engine is well 100000 miles onit however my micra which is for spares (body no chance of MOT pass) only has 30000 onit HOWEVER i was gonna swop enginges but when i ripped out the passenger seat the black box thing was HUGE damb HUGE as hell:upside: (this is Spare Micra BTW)
so i started to look carefully at the engine and the whole carb is electronic is this normal? both are K10 LS 1992 both J reg the block and head look exactly the same any help wld b apreciated coz its a mint engine
ALSO How many Pennies Does the Engine have and where do they sit? My Road Micra aint got none so i can only use for shops dnt wanna ova heat it
(this is a 1.0L engine)
Thanx in advance
The later 1.2 engine had fully electronic ignition and closed loop fueling via means of an electric carb. You do not need to swap this all over and fitting the other manifolds from the previous engine will work on this one.
Ed
