But if I don't know which wire the fog lights are running on in the plug (picture above) then how can I put a switch to it, the I sea is up wire the fogs up to a separate switch (saving me from hunting for a rare+expensive fog light stalk/stem)
Step 1: Find 'Driving lamps' relay under bonnet (is front fogs)
Step 2: Run a wire from 1 of the coil pins on the relay to earth
Step 3: Run a wire from the other coil pin through firewall (find a spare grommet and cut a slit with a knife in it) to one side of switch you mount on dash
Step 4: Run a wire from other side of switch to a live feed on the ignition barrel.
You sure that's not rear fog light? On mine I have Headlamps, Driving lamps and Fog lamps all seperate, driving lamps being front fogs. Just pop the bonnet and check the relay boxes under there
