Hi Folks, I'm new here and need help (in general, but mostly with my car!!) ?. I have an X reg Nissan micra 1.0.
I don't know if there is some kind of electrical fault or shortening happening but I am getting weird faults all at once. First my left indicator light starting going at double speed. Then the next day this has returned to normal and my audio has stopped working. There is no sound coming from my stereo (not the original micra one but one I have had for years with no problems), no matter whether I try cd or radio or how much I turn up the volume. At the same time, hubby has also noticed I have a headlight bulb out on the passenger side. I only just fitted brand new bulbs a couple of weeks ago for the mot, I'm not sure how long it's been out.
Could these be related? I tried a new audio fuse in the fusebox to no avail. As a side note, I have an engine that judders and pulls backwards for the first ten minutes of a drive when the engine management light is off, but that works when the engine management light comes back on, which it does intermittently! I suspect this may be related to a relay I replaced being faulty or not as good as it should be.
Time to sell it?!? ? Any ideas welcome for what's going on! Thank you ?
