Just 25 yards from home, so that's good anyway. I sat in, moved off, clutch in for 2nd gear, a bang and the pedal disappears! On closer examination the cable is un-hooked from the clutch actuating lever and does not move if I lift the pedal by hand. Pedal stays up or down where I leave it from inside the car. Pulling the cable from the engine end does not move it. New cable? I would have imagined I could pull the cable from the engine end if it's busted, but then, what would I know? Oh, and it's a 2002 model. Any suggestions gratefully appreciated.
