micra_pete
please note i cannot be held accountable for any mis-types / in-accuracies on this list, you are responsible for checking before working
nats - not coil pack type
101 injector 1
102
103 injector 3
104
105 oxygen sensor
106 fuel pump relay
107 ground
108 ground
109
110 injector 2
111 aac valve
112 injector 4
113 aac valve
1 power transitor (coil)
2 comb meter, n-cvt
3 resistor
4 eccs relay
5
6 ground
7 consult
8
9 cooling fan relay
10
11 n-cvt, air con, a/c relay
12 ign coil, injectors, air con, ign switch, fuse block - power
13 ground
14 consult
15 consult
16 maf
17
18 engine coolant temp sensor
19 oxygen sensor,
20 throttle position sensor
21 maf, tps, engine coolant temp sensor
22
23 consult
24 comb meter
25 n-cvt
26 nats
27 n-cvt, abs unit
28
29 maf, tps, engine coolant temp sensor
30
31 cam shaft pos sensor
32 comb meter
33 diodes
34 fuse block - power
35 neutral switch, n,cvt
36
37 tps
38 as 47
39 ground
40 cam shaft pos sensor
41 air con, duel pressure switch
42 n-cvt
43 power steering oil switch
44
45 air con, a/c switch, fan switch
46 fuse block
47 cam shaft pos sensor, maf, eccs relay
48 ground
non nats or very very early nats I
101 injector 1
102
103 injector 3
104 fuel pump relay
105 oxygen sensor
106
107 ground
108 ground
109
110 injector 2
111 aac valve
112 injector 4
113 aac valve
2 comb meter - tachometer
3 resistor
4 eccs relay,
5
6 ground
7 consult
8
9 cooling fan relay
10
11 a/c relay
12
13 ground
14 consult
15 consult
16 maf
17
18 coolant temp sensor
19 oxygen sensor
22 cam shaft pos sensor
23 consult
24
25 n-cvt
26
27 ABS
28
30 cam shaft pos sensor
31
32 comb meter - vehicle speed sensor
33 fuse box, consult, diodes - power
34 fuse box - power
36 ignition coil
37 tps
38 as 47
39 ground
40
41 duel pressure switch
42 n-cvt
44
45 cooling fan relay
46 injectors, fuse box - power
48 ground
101 injector 1
102
103 injector 3
104
105 oxygen sensor
106 fuel pump relay
107 ground
108 ground
109
110 injector 2
111 aac valve
112 injector 4
113 aac valve
2 comb meter, n-cvt
3 resistor
4 eccs relay
5
6 ground
7 consult
8
9 cooling fan relay
10
13 ground
14 consult
15 consult
16 maf
17
19 oxygen sensor,
22
23 consult
24 comb meter
25 n-cvt
26 nats
27 n-cvt, abs unit
28
30
32 comb meter
33 diodes
36
37 tps
38 as 47
39 ground
42 n-cvt
44
46 fuse block
48 ground
101 injector 1
102
103 injector 3
104 fuel pump relay
105 oxygen sensor
106
107 ground
108 ground
109
110 injector 2
111 aac valve
112 injector 4
113 aac valve
3 resistor
4 eccs relay,
5
6 ground
7 consult
8
9 cooling fan relay
10
11 a/c relay
12
13 ground
14 consult
15 consult
16 maf
17
19 oxygen sensor
23 consult
24
25 n-cvt
26
27 ABS
28
31
34 fuse box - power
36 ignition coil
37 tps
38 as 47
39 ground
40
42 n-cvt
44
48 ground
