ecu remap and engine manigament light
jim_bling
few things really
.I have herd that you cant re map my ecu is this correct as its the 1.4 last k11 before the k12
.If i had two lambada sensors is there a way to turn one off as my engine
manigament light is always on
if i cant remap my ecu is there another ecu i can use for my car or is it going to be to much of a fuss
also what else can i do apart from manifold decat and custom cat back and exhaust air filter and then cams will bigger injectors be better when i get the cams done i will only get it remaped after the cams and injectors but want to know if its possible first cheers guys
You cant remap the CGA ECU.
Omex can be installed to replace this although is not cheap to fit/map.
Alternatives is earlier K11 loom and ditch the coil packs for a distributor although you'd have to do something with the head for it all to work.
Eds your man for this.
kenny
you might be able to piggy-back the 2nd lambda signal wire onto the 1st lambda one.
and you need to find out what cc your topfeed injectors are really, before deciding on upgrading
