hissyfizzy
I've been sent an early Electronic Distributor to replace my defunt points based one.
I've read through some posts have said that these distributors will direct fit, one question mine has one wire and earth socket the electronic one has two wires plus earth socket, Haynes manual shows, or appears to show, one wire left off is this correct? Do I simply connect both of these wires to the same coil point? or not
I'm sure some one out there will put me in the light
Sammo sent the handshake Distributor arrived thanks
No one? someone must have replaced the points based distributor with an electronic style one
