order'd these, scroll down the bottom of the page
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200629286364
rack up the opinions please
I say you can't complain when you're saving around £500.
they,re not really height adjustable mailys, you can gain a bit of height if you increase the preload (tho that makes them even stiffer)
you could lower them about 30mm if you use the spring helpers (but i doubt you will want to lower these tho lol)
polly p,s are true height adjustable ones, where B is the height adjusting collar, and A is the preload adjustment eh
Yeah I know that I assumed that it had been discussed on the forum enough for people to all have their opinions. maybe I've just read everything wrong :blush::grinning: ok mate, but these are the short cut way, the expensive one's are the professional jobby
I'm taking my sisters apart tomorrow so I can put the helper springs back on so I'll do a short guide (Y)[/QUOT
whats the result, when you do that
thought i'd finish this thread as they have been fitted
very suprized at the handling at all speeds its smooth, motorway -yourway and myway its all good only the matiz set up franks/malcolmt/baguette got running is better for the budget modds, other wise its them very expensive coilies like pollyp
brilliant !
