Alfonze Ex. Club Member Jan 22, 2009 #1 right the main beam on both sides work but the left driving light doesnt work where as the right one does. Is this a MOT failure or what could it be?
joesouthgate Super Moderator Moderator Club Member Jan 22, 2009 #2 With super s bumpers it this? not sure if it would be an MOT failure tbh but it won't be difficult to fix, probably just the bulb.
joesouthgate Super Moderator Moderator Club Member Jan 22, 2009 #4 I've not seen driving lights in a standard bumper? Do you have a picture?
OP OP Alfonze Ex. Club Member Jan 22, 2009 #5 i mean its the 2nd selection on the stalk before main beam, off driving lights, full beam
joesouthgate Super Moderator Moderator Club Member Jan 22, 2009 #6 Oh right so dip beam works but main beam only works on one side, i get you now, yer change both bulbs if i were you as it is advisable to replace pairs. oh and yes this will fail an MOT.
joesouthgate Super Moderator Moderator Club Member Jan 22, 2009 #8 huh? Sidelights - 1 click Dip beam - 2 clicks Main beam - 2 clicks and stalk pushed away. So which one doesn't work?
Simonh Midlands Rep Jan 22, 2009 #10 does not matter which one it is...if its a light in your main headlight then you will fail an mot if it does not work. just replace the bulb
joesouthgate Super Moderator Moderator Club Member Jan 22, 2009 #11 well the bulb is a few pence and very easy to replace and yes it will fail MOT if one doesn't work. Simonh said: does not matter which one it is...if its a light in your main headlight then you will fail an mot if it does not work. just replace the bulb Click to expand... I know, i was just trying to establish what wasn't working for my own sanity! lol
