Drive shafts and hubs.
I need later style large drive shafts and front hubs for my Grass track Class 4 Project, I have small 998 type already and need the larger ones for my 1300 late LSD Gearbox.
so all i need is the later shafts then?, just to confirm dont want to be buying the wrong bits!
and the 2 rubber mounts and their brackets, and gearchange, and the cross member is slightly different, (and f/w and clutch eh)
here,s the 2 types of bare shaft
The mounts gearchange and all that rubber guff can be forgotten the engine will sit in a craddle that bolts in place of the front lower panel and the front rear cross member, and I will make up a linkage to suit. Quite a lot larger arn't they?
