Door Card Glue Removal
hoodedreeper
Hello,
What can i use to get the glue off the doors after taking the door cards off? This stuff is seriously sticky,so any tool i use to try remove it is gonna get covered in the stuff.
Is there any solvent(s) i could use that'll 'strip' it off without damaging anything else.
I've got some Adhesive Remover (aerosol) i got from halfords aaages ago i could try.
Any ideas?
Soapy warm water? er, label remover.
EBAY LIST
If you've got a misses, you could try her nail varnish remover, but do it in a inconspiculous area first.
what bits are you on about mate teh stuff that holds the plastic onto the door or on the actual door cards as when i done mine it just came off and was smooth with a lil bit of a sharp knife down where the glue went
When you remove the door card...theres a plastic sheet underneath the actual door card. You peel this sheet off and theres a sticky beige colour glue left on the door. I still havent had time to remove it yet,may be a weekend job
