I can supply an ECU that will remove nats on your car. Its £100 + ECU (I need to be supplied with a non-nats one which I modify) I can also supply that which usually adds about another £40
Ed
Nats wont in any way affect the Pectel ecu. Nats and the ECU are seperate devices, but the nats does talk to the ecu IF the ECU is nats enabled. If not then it becomes irrelevent.
There are different versions of wiring for the K11 obviously nats and non nats. Its likely that the Pectel ECU is wired for the non nats version which is why it will not be working on your Nats equipped car.
Ed
