Does facelift front bumper with fogs fit earlier 1996 model?
Looking to replace my front bumper without fogs to the facelift front bumper with fogs and Was just wondering if it's a straightforward fit?
Different shape for the lights and for the facelift bonnet.
Not sure if the mountings are different.
Someone did fit a facelift bumper to a facelift with some work but it looked cack where the bonnet should have been.
Came across this in a breakers yard it's listed as a gx. ...... will this also fit?
It's a poor quality pic but looks to be same colour too. What tools are needed? Don't think me roll cab and top box will fit in the micra lol
Seen this one if it's any help but it's near London and too far for me to travel
So eventually got my bumper into work and took fogs out ready for prep but after speaking to an auto - electrician he says the rear window heater switch I took from the donor I carnt use to wire up fogs as it has a relay inside so means the lights would come on slowly..... anyways can i modify this switch some way or will I need the front fog switch instead?
Aye, Tom here gave me a spare rear fog light switch to use :) Was just a case of using a multimeter to find out which pins were switched ones, then using it to switch a relay feeding the front driving lamps :)
I was thinking of getting another headlight adjustment switch, mounting it next to the existing one and use it to control the front fogs (position 1 for off, 2 for on, 3 for flashing lol)
...position 4 for strobe?
*gets glowsticks out*
Sent from my RM-892_eu_euro1_205 using Tapatalk
Position 4 flashes the lights alternately and plays J-Pop from a hidden speaker behind the bumper. Position 4 is only to be used whilst drifting - it's the rules.
Got me new toy :) ... bumper has been painted just waiting for my new front crossmember before I get bumper on and wired up
Behind the dash? No, as standard they're wired to come on with full beam and wired as such. If your car has the plugs in the engine bay they will be 2 pin brown plugs on either chassis leg near the grill iirc
I have a 1.3 slx so doubt it will have the loom but I do have a loose brown plug and another that is plugged in, my issue is I wanna use them as daytime runners so would be pretty pointless if they only came on with hi-beam
