Hi everyone
My 94 Dot has decided to not start properly in the past fortnight. Instead of starting instantly, for the first few goes the starter motor spins and doesn't turn the engine over at all. The next few goes it makes a screechy/grating sound (like when you accidentally turn the igntion key too far when the engine is running). Then after attracting enough attention in car parks it then starts normally.
Does this sound like the starter is on its way out and would i be best buying a recon starter £70 ish from local factor or risk a scrapper unit?
If it helps, the battery shows 12.84volts, so maybe it doesn't have enough power and needs to be replaced?
Anyone got any ideas?
Cheers!
Cheers!
