Distributor help.
Hello,
I am new to the group and would like your help, I have a problem with the distributor of the car and I want to replace it, but I do not know how to order the correct part. The car is a micra k11 1.0cc, model 2000. The distributor writes 2210074B00, I find it in the trade but not the specific number, if I buy one for micra k11 1.0cc, but with not this number, it will work, it will be compatible with the specific car.
I am look forward to hearing from you....please help me.
Thank you very much.
All Micras with de CG10DE and CG13DE distributor engines had the same distributor. So you can probably get whatever is compatible.
I don´t know about this part number 2210074B00 but searching for the part i came with this other part number: 2210099B04.
A new dizzy might be a bit pricey so you can also try on secondhand apps or breakers.
*Just checked and it seems that the part number changes through the years from 1992 to the las 2000, but you can check that the parts are the same so there should be no problems with any dizzy from a K11*
Thank you very much for your answer- help. The problem with the replacement is that I have found distributors but they have 5 pins plug but my car´s plug has 6 pin. I already have discuss this issue with mechanics but no one can surely answer about it. Thank you.
Checking the manual it looks like all models had the 6 pin and 2 ping connectors (for the ignition coil and transistor).
However it seems that from the connector only 5 pins out of 6 are used. (I checked on both manuals the early and late dizzy micras and looks the same).
I am gonna check today on both of my micras (1994 and 1995) as they should have the same 6 pin connector.
*Checking online seems difficult to find a new one that is the correct one so i would really check for a second hand one from a breakers*
Dear friend, I have to inform you that I finally fixed the distributor and the car is ok. Nevertheless, thank you very much, bacause you really helped me and the car engineer.
