Pistons + rods from Fusion Motorsports (if still available), Megasquirt ECU, better headgasket (have not researched that one yet)
Have not decided what turbo to go for yet, i have a Garret T03 in the garage but that would be far to big and laggy (good for up to 350hp max) so maybe a turbo from a Saab or something like that, that has a limit close to the power im looking for.
Exhaust will be a straight 3" with just one freeflow muffler in the back, to help spoolup.
Im asking because i want to do as much research as possible before i get started, and i want to know if there would be any disc brakes that would be pretty much bolt on, or if Lathe and CNC work will be needed.
I have found a possible donator car but its a CG10, but i think i might start with that since its the same block and bore as CG13, do you know if the head is different?
