T
trevor72
Hi all,
It's been a very long time since I've posted, but here I am again. My red micra has since past as I think I did post a long time ago, but my question is to do with my GF's 87 canadian micra.
Ok here it goes...
The car was running ok, (well pretty much like poop, even after much tuning the carb) but running anyways, then it just died one day and wouldn't pass fuel through the carb.
Today.. new carb, off another 87 canadian micra. I swapped linkage (carb was from manual, our is auto) and good to go right... WRONG! The car ran GREAT for about 5 minutes until it got slightly warm, then shut off! I've been trying to mess with this soo much because my GF really needs wheels! No success. The car is the same as before the original carb craped out! Don't get me wrong, the car runs great until warm. The warmer it gets the more throttle is needed to even get it to start again, and it wont stay runing unless you keep your foot in it! I've resorted to violence and started removing what I think is emissions junk in the hopes of finding something wrong.
Now can someone post a pic (or describe) what is NOT absolutely necessary for the micra to run. Please..pretty please I've removed the AB valve and the elevation something-ometer and the connecting hoses. I plan on plugging those tubes coming from the carb and see if this helps. that's another day.
Can you guys think of anything else for me to check???? My next step is to pull the head, but I really don't know why as the car has ~ 140psi cranking with the motor screeming hot (all plugs removed of course.). and It doesn't noticeably use coolant, that I can tell, and I;ve pulled all plugs a bunch of diff. times and never are they wet! Oh, the other thing, could someone post a pic of their spark plug, as is pulled from a good running micra. Again, I;m begging you guys here. My plugs are comming out all BLACK, sooty and not even a hint of brown. This to me sound very over-rich, but the hitachi carb is un-tunable! The car has good spark, fuel, and compression, what I'm I missing? BLAH! Arg, getting sick of this car, but I know it has to be something, just tired of throwing money at it!
Thanks,
trevor
Ok here it goes...
Thanks,
trevor
