CMF_kiwibuilder
» CMF MemberHello
My wife just brought a K11 1.34L and she is after more top-end power. She used to have a BZ-R Levin with a 180hp N/A 4age in it which redlined at 9,000rpm.
She has asked me to investigate in getting the CG13DE to rev higher and make more power.
So far I have a set of 1L Pistons which with my maths caculations should give me a compression ratio of around 11.6:1 which is good but now I am thinking about fitting the shorter stroke 1L crank with the longer 1.34L rods which should De-stroke itt.
Q1: Is the 1L crank strong enough with new rod bolts to take the 1.34L rods?
Q2: With running a twin webber carb set-up and a WRX style air scoup (basic ram-air) would the head be able to cope with the 9,000rpm I am planning to run the little engine to?
Q3: Valves/Valves springs would be able to cope with an increase in max rpm?
Q4: Would the rods be able to take the increase in rpm as the shorter stroke means they work less then a longer stroke engine?
Thank You
Aaron Nelson
Thank You
Aaron Nelson
