Delay Lighting ?
CMF_liion
Dutch : welke reglage moet men voor de ontsteking hebben?
French : Quelle reglage doit-on avoir pour l'allumage 10° ou plus ?
CMF_NotAnotherSSS
I know!!!
Ignition keeps coming up with lighting when converted from english to dutch, I have no idea what the word ignition is in dutch.
But he wants the specs of the standard ingnition timing for the CG13DE!
CMF_liion
Hello,
Yes, "But he wants the specs of the standard ingnition timing for the CG13DE!" :)
with the "consult nissan" the maximum is of 15°.
For is the moment it on 10° with a manifold and it is correct ?
CMF_NotAnotherSSS
english: 15° should be fine
dutch: 15° zou fijn moeten zijn
english: Are you using a custom design manifold?
dutch: Gebruikt u een verzamelleiding van het douaneontwerp?
english: With 98RON petrol you probably run even more than 15° but it is best that you just try different settings and see what works for you.
dutch: Met benzine 98RON stelt u waarschijnlijk zelfs nog meer in werking dan 15° maar het is best dat u enkel verschillende montages probeert en ziet welke werken voor u.
Cheers partner
CMF_NotAnotherSSS
Oh an exhaust manifold!
Oh een uitlaatverzamelleiding!
Anyone want to help this fellow now?
Iedereen wil deze kameraad nu helpen?
Ik ben niet zeker wat de cg13de timingsaanpassingen als zodat ik zijn kan u helpen niet meer!
CMF_liion
Yes,
Better Performance mit Manifold Exhaust.
the timing should be with a janspeed performance manifold !
it is difficult for me to speak English
CMF_kneival
Timing should not matter with a new manifold, just stick it at 17 degrees and run 98RON fuel.
A "power boost valve" or something that ups the fuel pressure may help, but the ECU will more than likely rule this out most of the time.
The best way forward is with a piggyback ECU or full ECU change to allow a tuner to set up your car to make the most of the new exhaust
