kennierobo
Buy & Sell Member
OK help I wired clocks from super sport to fit the micra shape following the guide set down here word for word. (for the connection of rev counter) blue wire on dizzy to wire on black plug on clocks quess what it worked for about 5 seconds then micra died so I have taken wire back off and car started again but only for about 5 seconds now it just turns over and wont start so whats went wrong and whats the remedy I was hoping to have this finished today now its all gone tits up..................:down: :down: :down:
Just re fitted the original clocks car still wont start removed number 1 spark plug and did the spark test looked orange and weak not the usual strong blue also i noticed when i put the original clocks back in the orange engine managment light is flashing none stop so with this in mind has anyone some ideas. wire that i put in for rev counter is now removed so everything is back to standard form. After searching on here and ciscos it would appear that the nats system has something to do with whats went wrong HOW or WHY I dont know I would have thought that if there were issues with things that could or can go wrong then you guys on here would know first hand, If I had known that by connecting a wire this may or could happen then I wouldnt have connected it. But that said theres nowt I can do about it now and like the old saying there is no cryin over spilt milk, But I would like to get her running again it was going back on the roads 2morrow but now thats out the window. After searching both here and there im no further forward nats into none nats will wont work. So question is once and for all and again searching provides me with the name micra pete he seems to be the man for this one. If I go to the scrappy and get a NONE nats ecu will it just plug and start without the need for key re programing or will i have to do some wireing to get it up and running not a problem, Or option 2 do I have to find a nissan dealer tow car there get them to sort it out (try not to) 3rd option tow car to m8s breakers yard strike match and keep warm for an hour or two.......Is there a way around this that dont involve nissan ie the purchase of an open ecu unit if so where and who and how much just point me in the right direction or all my hard work will have been for nowt......................losing the faith now.
