Guesst4094 Feb 19, 2016 #1 Okay, out of 10 (10 being hardest) how are the facelift dashboards to remove? and what sort of time scale? Thanks in advance.
infinity Feb 20, 2016 #2 For your first time probably an hour I recommend you drop the steering column makes it a lot easier and that way you don't have to remove steering wheel. Apart from that its following the trim removing screws
OP OP Guesst4094 Feb 20, 2016 #3 Thank you I might wait till I get around to changing the steering wheel then, it's slowly getting higher on the list
