cylinder head
CMF_giannishazel
well my cylinder head is already shaved 0,4 but due to a bad gasket i need to schim it again.at 0,4 i didnt have any issues with lower chain,tensioner noisy motor etc.the engine is cg13 and i know that it has 9,5-1 compression and at 0,5 it will propably reach 10,3 to 10,2-1(i will do the maths later!)but i am not sure about the tension of the lower chain..the whole set chains,gears tensioners etc is new..has anybody done the 0.5 schim?will it be ok for some brutal use?
CMF_giannishazel
wow!!!2 mm?didn t you have problems with the tension of the chains
?esp the lower one?i guess you had modified the tensioners..or something...you had shaven the head and the block as well cause 2 mm is a lot imo...in that case 0,5 is fine....thanks frank
