Hi All,
Sorry to join the forum just to ask a question, but hopefully somebody can help with this one.
I've been trying to remove the cylinder head from my K11 so as to replace a blown head gasket - this is something I did a few years ago on a Sunny so I had some hope of success, sadly I've got a bit stuck.
I followed the Haynes manual as far as disengaging the upper timing chain from the camshafts, and then removing the idler sprocket retaining bolt and washer. Then the manual says something about prising a shaft off with a screwdriver, and then removing the upper chain - that's where I am stuck.
On removing the bolt, I find the sprocket - actually there are two sprockets, one engaged with each chain, which seem to form a solid piece of metal - is pulled down a mm or two by the tension in the lower chain. It is forced down against a small ridge of metal extruded from the head, the upper chain is held between this bit of the head and the sprocket. That means I can't get the upper chain off the sprocket, it also means I don't see how the head is ever going to come off, not without mangling that chain and sprocket at any rate.
Also, like I say the whole sprocket assembly has been pulled down a bit, this means I now cannot get its bolt to screw back in, so even if I could get the head off how can I reassemble things?
As far as the 'screwdriver prising' business goes - the sprocket is loose on a shaft, it won't come all the way off though, I don't see anything that can be prised.
So, have I got something wrong here, am I missing something? As it stands the only way forward I can see here is to remove the lower chain cover, then the lower tensioner(s), that should allow the idler sprocket to move up enough to disengage the upper chain. But I don't see any way of accessing the bolts holding the lower cover on with the engine in car, and removing the engine is beyond me I'm afraid.
So, any suggestions - if not the thing is off to the scrap yard...
Cheers,
Tim
Cheers,
Tim
