So the bent dipstick issue is sorted! Onto the next issue lol.
Basically, my cylinder 4 is running very hot, you can see that the GizFab 4-2-1 manifold is turning 'blue hot' on the 4th cylinder. This blueing has been getting progressively worse. The photo shows how it is currently. The manifold went in on the 10th March, so this is how much it has blued in just under a month. After parking up and coming back to the car after about 30 min, I could easily physically feel the difference in temp betweek cylinder 4 and the other headers. Interestingly, cyl 1 felt the coolest, cyl 2 a little hotter, then cyl 3, and then cyl 4 MUCH HOTTER.
Been advised it could be a faulty injector? thus causing cylinder 4 to run lean? thoughts?
