madmezza
Has anyone actually changed the brushes on a CVT gearbox? If so, what was the car like before and after?
I've had a scary conversation with Nissan about them. Basically, they are an inspection item at 27k miles, not a replacement (my car's done 41k miles). And apparently, when you take the brushes out, you need to shine a torch into the hole and look at the contact point on the clutch assembly. If it's all black, then there's been lots of arcing and the clutch assembly needs replacing - £900+VAT for the part!!!
So, I'd love to know what it feels like when the brushes are low, to determine if I need new brushes or a new car! My car seems to need more revs to pull away from a standstill - and so takes a little longer to get moving as the CVT control unit doesn't apply high revs straight away. Also, going up hills at 70mph (ish) can be hard work...!
I do lots of motorway driving, so the car's usually doing 70mph - do you think this will wear the brushes quicker??
Cheers for any info/advice
