they need minimal modding compared to polo ones. top mounts need hybridizing and one of the mounting holes need widening by a mil or two
with the corsa ones theres no need to strengthen the adjusted hole
the top of the wheel flops down to the ground when cornering, the shaft is bent double and locks up, and the steering snatches to full lock..................is all scotti cant see much problem in it tbh, if its done right, whats the worst that can happen (seriously) majour camber, i had 8 mm bolts in the 12mm hole on that top mount for months, hadr driving and even hit a curb and didnt even shift so the top hole isnt load bearing and under immense pressure
