If I was to simply buy some drilled and slotted brake discs and put them on the front wheels, would I be able to complete the upgrade simply by buying a set of brake calipers that are bigger than the stock calipers and fit them provided they fitted inside the wheel hub when driving, or would I also need to line up the two brackets that hold the stock calipers in place with the new calipers? Buying a set of stock brakes from another Nissan that are bigger than the current ones is far less expensive than going out and buying a set of custom big brakes.
Also, what the heck do you do about the ABS for rallying and racing? Every time I stomp the brake the ABS kicks in and weakens the braking so I stop over a longer distance. I know it's essential for daily drivers, but this is also a rally project car.
