Marvelous... back to the standard tb i suppose then.
...but no need to use it on a "normal" setup.
the GA maf just screws off, but the CG one needs to be de-soldered really, but they are a different shape thoi'm very confused haha, so i can swap the standard one over with the ga one??
looks like i'm going back too standard then.. gah
Did you see much of a result with the ga16 t/b on the 1.0litre?
Have you tried unplugging the maf? Or used an adjustable fuel pressure reg to suit the larger t/b?
It overfuels anyway (even more at idle), no need for a FPR...
I noticed that it overfuels at idle and low load (made my grey rear bumper go black, like a diesel) and sometimes it would underfuel at high revs, dont worth the hassle really, just stick with stock TB/MAF if you dont have any crazy setup...
Ah ok, thank you. I still might give it a shot as I'll have quite a custom setup. Would you recommend the SR20 MAF as a better alternative to the GA MAF on a 50mm t/b?
TMRS says it runs ok on the stock ecu, but goes super lean at 3500 eh matt http://www.micra.com.au/community/message.php?messageid=33570Ah ok, thank you. I still might give it a shot as I'll have quite a custom setup. Would you recommend the SR20 MAF as a better alternative to the GA MAF on a 50mm t/b?
