I believe there is a cable with plug on the end that comes from the plastic rotating ring behind the wheel, and 1 of the wires is the live feed to the horn switch and the steering column is the earth. If the contacts in the plug touch the column it will short, causing the horn to come on. Otherwise, your aftermarket horn button may be stuck in the closed position?
