could these be modified to fit
hey just seen these while looking for some wheels not really what i had in mind but if they could be modified for now to fit my car it could be worth it for a while so could they be done to fit :/ ????????
depends how you want them banded, he only need 4 as he welds in a steel band to any width, within reason. 8 wheel widening is where they cut the rear half of the wheel off one set, the front off the other and weld the back onto the front, this way you only have 1 welded seam, instead of 3, and you can only go as wide as the rear section allows
