Blake
right didnt feel up to fitting my 1.4 cams myself, so....
got a mobile mechanic who id been recomended to do them thinking everything should be ok
well he cracked on with the car this morning, its done but when its running its rattleing very very loadly and runs badly!
so i wasnt happy so i took it to a local tuners and thay looked at the shims and there has to be a 5mm gap between some of them some you could fit a pound coin between!!
he must have noticed the clearences and thought f*** it its his car!
so now im £70 down and could have bent valves.
i rung the guy up he says hes coming back tomoro morning but he proably wont.
gunna try my cg10 shims with the cg14 cams because the cg14 shims has left the huge gap. does anybody know if this will solve it?
why would there be a problem with clearnces if he fitted the cg14 shims along with the cams?
i might have to put the cg10 cams back in if he carnt sort it and tbh i dont trust him to sort it but it has to be done and help guys????
