corsa coilovers ?
they can be made to fit. Gaz are a great make, but a bit pointless spending that much on a pair of fronts, better off getting a raceland full corsa b kit for £150. or if you want to spend a few hundred more get micra specific ones
hybrid topmounts, slot one of the lower mount holes. rear dampers need a mm or so shaved off the lower tube, springs are no good, have to cut standards on the rear
