Coolant temperature display readout.
Hi all, has anyone successfully hooked up a temperature display fed from the built in coolant temp sensor?
Just thinking it would be a cool mod as the dial can be a bit vague and I wanted to use the same display to toggle between exterior and interior cabin temperatures too. If the temp sensor signal is no good, can an extra sensor be plugged into the loop somewhere?
Yeah looked into that and it's neat. Only thing is I'll need to buy a connector which might be costly. In the long term I'll probably get one though
