haha i have to agree that lip is ugly:laugh: there better done how you do them frank plus you dont have to worry about doing the arches then either (Y)
they,re a right mission karl, far harder than reversing themFrank if I brought enough wheels to you would you make a set?
When they're reversed is the valve reversed as well?
the centres are a very tight fit karl (you could literally drive on them without welds) so you cant physically get the eccentric, you just have to spin and chalk them on your rear hub to check they are running trueThought so better to be sure, do you use a jig to make sure the centers are level?
