My K11 is due its first MOT with me as its owner next week. What are the common failings that I should check? So far I've found a split CV boot and an outer track rod end needs replacing which I believe would both be failures.
I do have a small leak in my back box, would this usually pass? Front crossmember is a bit off too, I poked a couple of small holes in it when I was underneath doing the drive belts. No other bad that though.
I've never actually owner a car long enough to have to MOT it!
