matiz complete front legs, and matiz rear springs and corsa shocks rear currentlyFranks running matiz fronts, corsa rear with cut springs i believe
frank said:matiz complete front legs, and matiz rear springs and corsa shocks rear currently
matiz rears on the rear mate, and you have to swap the topmount over and slot one of the lower holes.hi frank dose the matiz frout leg fit right on the micra with the matiz rear springs and the same with the corsa shocks and what springs do you use on the rear
they,re about 50mm shorter scott, and about the same weight/strength spring, here,s craig,s matiz legs with about 3 coils off (about the same height as my ones with the lowered perches)Frank what is the ride/ride height like with std matrix struts?
Scott
If that's stock and I using the same But I'm missing two coils then I'm in trouble hahaHeres mine with stock matiz fronts
johnbr6 said:How bouncy is the matiz set up?
