Hi all,
When i pull away in first, sometimes i get a judder which feels like the clutch engaging. Changing gear normally is no problem. Only when setting off, could this be the alignment/how tight the pressure plate is? engine/transmission mounts or something else?
I will be changing the clutch cable after payday but any ideas would be good.
Matt.
p.s clutch doesn't slip in any gear
Matt.
