Hi guys ,
Have a 1.3 engine built , should be pushing roughly 120-130hp maybe bit more hopefully NA.
Will be getting Ikengineering to lightened flywheel to 2.75kg
I currently have two LUK clutch’s 160mm & 180mm. I currently have the 160mm cushplate sitting in the 180 friction plate . Just needing to bolt up .
-Has anyone ran this type of clutch before with big power?
-Will a standard 1.0 clutch be up to job ?
-would I be best off ordering 1 litre performcance clutch off eBay which can take 35% above factory rating ?
Finally has anyone any ideas how to drill the rivets on the Cush plate to keep the spacers .think they’re hardened steel . Drill bits keep burning out
