hi there, i think it is time at last for a picture of where i put the wire for clocks.
i spliced into a wire that came from the dizzy, check my blog, for the correct colour.
from the car that the tacho dials came from, i also cut the plug out, leaving about 50mm of wire, so that i could solder it on. the plug is the one directly behind the actual rev counter.
cut the plug out of your car, and then solder on the new one. all the colours are the same, so it is easy to match, but on the new plug that has been soldered in, there will be 2 spare wires, and it is one of these that you need to connect the dizzy wire too.
will get a pic in a min.....
right then, just had a look at the back of my clocks, the wire that you need to bring from the dizzy, needs to go to the blue and black wire, on the new plug.
also, i remembered, my old dials didnt have the clock on them, and the new ones did, and to get it to work, i bought a live 12v feed up to the clocks, and it goes to the red and black wire on the new plug.
hope this helps people.
here is the picture of the wire.....
here is another picture of the wire that you connect to on the new plug
here is the picture of the wire that i ran a 12v live to, so that the clock on the dash worked....
