to do that and keep the same millage you will need to have milage correction done on your clocks, although it is not illiagle to have the wrong millage on your clocks in this country so long as you state it at your mot and if you sell the car the new owner must be told the exact correct millage and they need to be given a reason as to why the clocks were changed because this is known as clocking other wise.
